Периодически загорается лампочка ABS
- DIMANIDZE
- Бармаглот
- Администрация клуба
NFBR0108S02
1. Drive vehicle over 30 km/h (19 MPH) for at least one minute.
2. Turn ignition switch “OFF”.
SBR535E
3. Ground terminal “8” of “Data link connector” with a suitable
harness.
4. Turn ignition switch “ON” while grounding terminal “8”.
Do not depress brake pedal.
Do not start engine.
SBR588E
5. After 3.0 seconds, the ABS warning lamp starts flashing to
indicate the malfunction code No. (See NOTE.)
6. Verify the location of the malfunction with the malfunction code
chart. Refer to BR-61. Then make the necessary repairs following
the diagnostic procedures.
7. After the malfunctions are repaired, erase the malfunction
codes stored in the control unit. Refer to BR-49.
8. Rerun the self-diagnostic results mode to verify that the malfunction
codes have been erased.
SBR535E
9. Disconnect the check terminal from the ground. The self-diagnostic
results mode is now complete.
10. Check ABS warning lamp for deactivation after driving vehicle
11. After making certain that ABS warning lamp does not come on,
test the ABS SELF-DIAGNOSIS in a safe area to verify that it
functions properly.
Стас АКА Бармаглот
